Having Trouble with Sync
Old May 13, 2009 | 11:05 PM
vjhpac's Avatar
I have an 09 XLT with the standard radio and sync. The phone button stopped working and so did the sync button. Any ideas on what is wrong? I haven't done anything to the system and it was working flawlessly the other day.
I push the phone button and nothing happens.
I push the sync button and nothing happens.
Old May 14, 2009 | 09:34 AM
BIG_ole_TRUCK's Avatar
Seems like you have a date with the dealer in your future. Perhaps the steering wheel controls have gone bad? Dunno, but let the dealer find out for you.
Old May 14, 2009 | 10:16 AM
matt_m's Avatar
Happened once to me the day after I got my truck home. I pulled the sync fuse, turned the key on, turned it off, put the fuse back in and it worked when I turned the key back on. My reasoning is that it does say Microsoft on the front so I'd try a reboot before taking it in. Haven't had the problem since, but if I do, I plan to take it in.
Old May 14, 2009 | 10:30 AM
6868vfco's Avatar
take it to the dealer they will reflash the three modules it is a common issue
Old May 14, 2009 | 10:49 AM
newmandl's Avatar
I think I remeber seeing a Sycn reboot process. It is a computer after all, and we all know how reliable those are.
Old May 14, 2009 | 01:15 PM
F_ast's Avatar
Depending on your phone, make sure the its radio is turned on or the truck might not know its even there.
Old May 14, 2009 | 01:25 PM
BrainDonor's Avatar
ahahaha!!
Old May 14, 2009 | 01:45 PM
sandydiego's Avatar
I believe the is a reset for sync in the main menu. The process is outlined in the sync manual. Not to hard and may save you a couple of hours at the dealer.
Old May 14, 2009 | 03:05 PM
matt_m's Avatar
But you can't get to the reset when this issue occurs. When it happened, it was like I didn't even have Sync installed.
Old May 14, 2009 | 06:12 PM
sandydiego's Avatar
Did you try the menu **** on the dash? This will take you to the sync menu. Is this not working as well? Start the truck and wait a minute. then hit the menu button.
Old May 14, 2009 | 06:15 PM
sandydiego's Avatar
My snyc was acting up and I have a thumb drive I use to "refresh" sync with. Gives sync something different to look at and clear out the cobwebs.
Old May 14, 2009 | 09:16 PM
matt_m's Avatar
I can't speak for the OP but on mine nothing sync-related worked. No way to get to it from the steering wheel or head unit buttons.
Old May 14, 2009 | 09:56 PM
vjhpac's Avatar
Thanks for all of the input...I'll try some of these suggestions this weekend. I did plug my iPhone into the usb today and it did NOT even charge, so I think it may be the fuse suggestion mentioned above.
