Aluminum LCA?
Old Apr 23, 2009 | 08:43 PM
Barritia's Avatar
If they wanted them to be stronger they should have gone with billet aircraft grade alloy it suffers a lot less to wear and tear than cast alloy does. Cast alloy really is a joke for strength.
Old Apr 23, 2009 | 08:48 PM
Ford was praising the aluminum LCA back when the 04's first came out, saying how much stronger it was than the competitor's stamped steel LCA's.
Old Apr 23, 2009 | 08:56 PM
BlackDawg's Avatar
There are several more advantages to steel from the manufacturing process to performance and durability properties to recycling after the vehicle is done than aluminum imo. I can see why Ford went to the steel and it probably is better for a generic application such as 500,000 trucks a year or whatever the number is. Having said that, aluminum can be made easily as strong if not stronger than steel even at similar or slightly less weight though it is more 'brittle' and while I'm sure examples will come out in this thread, the aluminum LCA's of the 04-08 have not been a widespread issue. IMO the aluminum LCA looks much better but I also think they both suck because at least on the 4x4 models it should be a straight front axle.
Old Apr 24, 2009 | 03:56 AM
Power Kid's Avatar
Originally Posted by v_tach
Sheet aluminum is more expensive because it needs more processing than cast alloy.
We have eight 08' F150's as fleet trucks Two of them have suffered suffered fractured aluminum LCA's. The parts have been replaced by Ford under warranty on all eight trucks with steel parts. Its the reason why I know the facts about the change to steel on the 09's.
Wow what the heck do you guys do to your trucks. We have 6 in the family and through work I know of personally another two dozen at least and no one's ever heard of this... Either had my dealer.
