Help 02 sensor
Old Apr 4, 2009 | 01:06 PM
Toolcrib's Avatar
Help 02 sensor
Does anyone know if someone makes an aftermarket 02 sensor for the 2009.
Ford already can't supply the part.It has been two weeks, with the check engine light on I feel like I am driving a tank.
Old Apr 4, 2009 | 03:07 PM
Deano-FX4's Avatar
how bad is your fuel economy?
what o2 are you waiting for? do you know what the code is?
i have been waiting for a upstream sensor for about two weeks as well.
putting a aftermarket part is not the answer, because if that sensor fails you have zero warranty on it from Ford, wait for the part, get it installed and this way if anything goes wrong you are not footing the bill.
Old Apr 4, 2009 | 06:44 PM
Toolcrib's Avatar
Thanks Deano,I didn't even think about the Warranty issue. I did not get the Code off the Dealer ,but I assume since it is affecting my mileage,and driveability at low speads it is one of the upper 02 sensors.I even got under the truck to take a look myself,make sure there were no loose connections,it would be a pretty easy job to replace any one of the 4 if you had the part.
What is Ford telling you, how long of a wait for the part.
Old Apr 4, 2009 | 07:20 PM
Deano-FX4's Avatar
well they aren't telling us much but when i went to order mine they were list back ordered USA, now since i am in Canada what that means no one or even Fords main part depot center has parts available in Canada or the states. which usually means there are a lot of dealer across north america ordering them or they have pulled the parts and are waiting to ship a newer version.
