Radio Trim Removal
Old Mar 11, 2009 | 05:40 PM
CobyMedic's Avatar
Radio Trim Removal
Anyone attempt to remove the radio dash Panel yet? I started to last night, there are two screws on the top that have to be removed but after that I cant figure out what to do, doesnt seem like it wants to move at all.
Old Mar 11, 2009 | 05:56 PM
Barritia's Avatar
I had most of the dash apart today. There is also another screw behind the Sync usb plate. You should then be able to remove the panel then.
There is a little notch under the plate that you can get a small screw driver under and then pull pretty hard and the panel will pop out.
Old Mar 11, 2009 | 05:58 PM
v_tach's Avatar
The Sync panel at the bottom pops out and there is another bolt behind it.
http://documents.victorytechnologies...duct/15785.pdf
Old Mar 11, 2009 | 06:07 PM
CobyMedic's Avatar
Thanks guys, never really thought for looking on Metras site.
ibcop's Avatar
Thanks for the installation instructions!
Old Mar 11, 2009 | 08:15 PM
ranger81's Avatar
I wondered how they were going to put aftermarket radios in the 09....
Old Mar 11, 2009 | 08:53 PM
CobyMedic's Avatar
Kinda sucks though, with FX4 I would just have a flat black panel in the centre of the dash instead of the glossy panel. Plus with sync and everythng else I am starting to wonder if it worth doing an aftermarket HU.
Sony is pretty good as it is....
