Big honkin' mirrors!
Old Mar 14, 2009 | 10:32 AM
Barritia's Avatar
Kazimp3 what are you doing lol
Old Mar 14, 2009 | 09:18 PM
ibcop's Avatar
Originally Posted by kazimp3
Well the dealer brought in the King Ranch and we took it apart. Sure enough there is a plug socket with a power fold mirror relay mounted right above the seat belt in the C-pillar. The part number for this socket is (F3DB 14489 BA).
I also checked for the wire colors going to the socket and they match the wire colors of V-LG, V,Y, V, R-Y, and B. I took my truck apart and there is no socket or wires that match that color scheme. I also pulled up the plastic door sills where all the wires run under and those colors are not present. When I took apart the door those wires ARE there and they run through the rubber hose into the cab behind the e-brake but I dont know where they go from there. I'm going to trace those wires and see where they end since they do not make it to the back of the truck where they should go. When I find them. I'm going to connect the socket and relay then the power fold should work. I'll let you know since I will be doing this today.
Wow! How did it go?
Old Mar 16, 2009 | 04:59 PM
HotLap's Avatar
kaz....what's the verdict...inquiring minds want to know
Old Mar 16, 2009 | 07:46 PM
ibcop's Avatar
Stop holding out on us......
Old Mar 19, 2009 | 02:34 PM
SteveVFX4's Avatar
guys, you do realize kazimp has the older style truck (08)?
The 09's most likely have similar wiring and most models are probably not prewired with the power fold module. But there might be a remote chance that either a 09 King Ranch or Platinum with the optional big tow mirrors might already be prewired with the power fold module since both of those trucks come standard with the regular style power fold mirrors.
