ModBargains.com - 2009 F-150 2" Leveling Kit
Looking to give your F-150 a more level stance, but don't want to spend hundreds doing so? An easy solution to this is the Pro Comp leveling Kit. This easy to install kit levels the stance of your F-150, by lifting the front an additional 2" to greatly improve appearance. The increased ground clearance allows for fitment of 33" tires on the 2wd, and 35" tires on the 4wd. The leveling kit will not change the overall suspension feel or steering geometry, allowing your F-150 to retain its factory ride quality.
Benefits
Fitment
Benefits
- Lift your truck on a budget
- Heavy duty steel construction
- Does not change suspension feel or geometry
- Black powdercoat finish
Fitment
- 2009+ F-150 2wd/4wd
