Opinions- User 2009 with 96k miles
Old Mar 27, 2013 | 01:51 AM
Archer_Cowboy's Avatar
Been shopping for a replacement truck (supercre Lariat). Mostly I've been looking at 04-08 models because they are in my price range.
Ran across a 2009 Lariat Supercrew. Except for one dent above the tail light, it looks like perfect. The one test drive I did it rode wel and engine sounded better than my last truck. And it's in my price range (upper end, but just). Being sold by the same Ford Dealer that sold it new.
Only flaw is 96,000 miles, or about 30k a year. Carfax says a single commercial owner and it's in ranching country.
Most of the trucks I've been looking at have similar miles, but are three or more years older. I'm worried about the amount of miles in such a short time.
Opinions?
Thanks,
AC
Old Mar 27, 2013 | 06:38 AM
jaws12's Avatar
I'd have the transmission serviced, spark plugs changed, all fluids changed, and go with it. 30,000/yr. prolly means alot of higher speeds so you may be ok. Good luck.
Old Mar 27, 2013 | 06:39 AM
worm5932's Avatar
5.4? Its pretty trusted. Id rather have a truck with 30k a year than 3k a year. Also the company I used to work for replaced their trucks right before 100k. A supercrew lariat wasn't out getting worked, it was taking 1 person to meetings and jobsites if I had to guess.
Old Mar 27, 2013 | 06:47 AM
Backnblack_66's Avatar
30K/yr is nothing for myself. I commute about 48-52k/yr
As worm said above....30k/yr to me is better than a 3k/yr that's been sitting...
Old Mar 27, 2013 | 08:45 AM
canadianelbow's Avatar
One thing to consider is that the '09's came out in '08, and with it now being late march of '13, this could easily be a nearly 5 year old truck, and is at least a 4 year old. Brings your average yearly down to somewhere between 19k, and 24k.
Old Mar 27, 2013 | 11:34 AM
The 09's also have the revised heads to eliminate spark plug removal issues, and have a 6 speed transmission.
Old Mar 27, 2013 | 01:10 PM
Awesome, thanks for the advice. Appreciate the willingness to help out a novice Truck owner.
AC
Old Mar 27, 2013 | 02:02 PM
cheef's Avatar
Supercrew is much larger than previous model. Front door is larger = better visibility. 6 speed is worth the coin over the 4speed especially if towing.
I wouldn't be afraid of the miles. Check the oil filler cap for sludge and get the vehicle maintenance history if possible.
Good luck
Old Mar 28, 2013 | 07:23 AM
rheagrimm's Avatar
96,000 mi. on a 5.4 means its just getting broken-in good. If it's been maintained properly then I wouldn't worry too much about the miles. Those engines have a reputation for living a long, long time.
