Debating on getting Rancho 4" lift.
Old Oct 15, 2009 | 11:43 AM
slimcubby's Avatar
I am really interested in getting the 4" lift since it won't be as big as 6" and can use my truck for work still. I get in an out of the bed all day long.
So I am thinking the 4" lift with my current 33's would be a good setup. I don't want to do any sort of spacer lift like AS since that caused me bad problems.
My other choice would be to go with some sort of coilover in the front only like KING shocks but they only give barely a 2" lift.
My main concern is that if I spend the $ for a full suspension lift is Rancho good quality? I don't know if I like that they reuse your stock coil when with fabtech you can get a whole new coilover with their lifts.
Old Oct 15, 2009 | 12:01 PM
redfx4150's Avatar
rancho makes a good kit and for the reused front shock all the kits do it. but they usually sell a up graded shocks to add to the kits
Old Oct 15, 2009 | 12:08 PM
slimcubby's Avatar
Yea I would probably to that route and get the new shocks as well.
One thing that I am going to call Rancho about is the rear lift is a block. I would rather use an AAL to also achieve higher load capacity. Wonder if I could get the setup like that.
Old Oct 16, 2009 | 01:41 AM
slimcubby's Avatar
Ok I am pulling the trigger on the Rancho 4" lift kit with upgraded RS9000XL Shocks. Going to try and figure out another way to lift the rear instead of using their block. I rather do some sort of AAL for more load capacity.
Old Oct 16, 2009 | 11:00 AM
F150NL's Avatar
I just looked on the Rancho Site.. Drool I want that lift lol.. But it would totally void my warranty on my 2010
Old Oct 16, 2009 | 11:15 AM
IDNC76's Avatar
how so ?
only if they can prove the lift caused the problem then they will void the warranty on the suspension
Old Oct 16, 2009 | 12:09 PM
slimcubby's Avatar
Originally Posted by IDNC76
how so ?
Exactly what I was going to say...
If your air conditioner brakes your lift won't void that being covered under warranty. etc etc
slimcubby's Avatar
How much $ do you think it would cost for the lift to be installed?
Old Oct 16, 2009 | 05:07 PM
BrainDonor's Avatar
Read this: https://www.f150online.com/forums/20...to-shocks.html
Not sure if it's directly related, but still interesting.
Old Oct 16, 2009 | 06:03 PM
slimcubby's Avatar
Wow!! That scares me to go with the rancho lift now. I had bilstein 5100's on my taco with not a touch of rust on them.
Old Oct 17, 2009 | 12:28 AM
statikuz's Avatar
I would guess something like $500-1000 to have it installed?
Old Oct 19, 2009 | 02:02 AM
slimcubby's Avatar
Yea I was thinking more towards the $500 range. Still debating the thoughts of getting rusty shocks.
Old Oct 19, 2009 | 08:50 AM
Wes28376's Avatar
I wouldn't worry about the Rancho's rusting. I have run Rancho's several times in the last decade and never had a problem.
That guy probably had a leaking shock that he didn't notice for a long while. That in combination with the weather from MA caused that. I doubt you would have any such problem where you’re from.
Bilstein is a better quality product so if you decide to go with them you won't be disappointed.
Old Oct 19, 2009 | 09:13 AM
sterling09FX4's Avatar
That rancho lift on the f150 on that site looks great......I may go that route in a few months as well.......let us know how it all works out!!
Old Oct 19, 2009 | 09:29 AM
°°Pat°°'s Avatar
Get the Rancho lift and buy Bilsteins shock... The best of both world.
