04 Crank no Start
Old Jun 26, 2025 | 07:05 AM
Cagedfalcon's Avatar
04 Crank no Start
Hello
Recently bought this 04 FX4 5.4 3v with the typical bad phasers & trans issues.
Successfully completed the phasers including a lock out kit( DON'T DO IT, power & mileage suffer in my opinion), including dropping of the oil pan to clear the pick up screen which was packed. Tried 3 times to solve trans issues while installed, but a shop ended up with that one.
Drove the truck for aboul a month, got tired of lack of power, wouldn't spin rears in loose gravel.
Desided to remove lock outs after replacing coils & injectors, VVT solenoids, & CMPs.
After pulling lockouts & reassembly, i got a P0353 code, then the truck died. Accidentally left #3 coil unplugged, no big deal....just plug it in & restart, well, no start. Checked all plug-ins, relays & fuses...nothing. It will spit & sputter a little with starting fluid, so must have spark. I don't get it, it ran about 30sec after reassembly & before disassembly (just no guts), has new PCM due to previous owner misaligned plug with PCM & pushed in 3 pins. Cams look good.
I did remove negitive cable for about 5-8min, tried to start, just cranks, no codes.
Need my truck back
Thanks, Paul
Old Jun 26, 2025 | 10:15 AM
Check the FPDM for corrosion.
Old Jun 26, 2025 | 12:28 PM
All good, very minimal. Jumped connector, still no fire. Going for fuel pump in morning.
Old Jun 26, 2025 | 06:08 PM
Did you check the FPDM or the inertia switch?
Old Jun 27, 2025 | 04:51 PM
getterdun's Avatar
Definitely sounds like a fuel problem. If your OBD tool reads fuel pressure that would be helpful.
Old Jun 27, 2025 | 11:28 PM
Ok, think I have it sorted.
I replaced fuel pump(fun times). Still no start, but pump now working, i had a leak at the fuel filter, sprayed when releasing the connector.
No power at injectors. Rechecked inertia switch, every fuse & relay.....again, all good.
Found the PCM pinouts for injectors, all good. I thought about reintroduce 12v to the injectors in desperation. Plugged Engine harness back into PCM, & checked one last time for voltage.......there it was!
So, I'm thinking bad wire at this point. Still getting a P0340, but running with more power & smoother. Tomorrow, I'm replacing the wires for the bank 1 CMP.
New CMPs, VVTs, but will test crankshaft position sensor as a possibility.
But for now, it's running strong & smooth.
Thanks all, Paul
