Trans fault, stall, and no start
Old Jan 18, 2025 | 10:41 AM
Got160s's Avatar
On the way home from work 55 miles an hour the truck just shut down and started making an emergency tone flashing transmission fault on the odometer screen. Now the truck turns over but no start. Its giving me a handful of codes ..p0962,p0753,p0750,p0748,p0743,p0740,p61B
I hope I didn’t lose the drivers in the pcm. The harness is good so maybe it that hard harness in the transmission??? Anyone have any ideas I would be grateful
Old Jan 18, 2025 | 01:50 PM
Year, model, and engine?
Old Jan 20, 2025 | 07:06 PM
Got160s's Avatar
2007 regular cab 4.2L f150 .. #1ftrf12287nao8631
Old Jan 20, 2025 | 10:17 PM
Those are all transmission solenoid, torque converter, and torque monitoring codes. Check all your fuses. It may be the internal harness.
Old Jan 26, 2025 | 08:41 PM
Got160s's Avatar
Update
So I finally got a chance to dig on in to the issue ,turns out the transmissions completely fine. the problem being no power well 5mv supplied to the solenoids and rear oxygen sensors . So bad pcm im pretty sure.. i can inject power on that circuit and the truck runs fine
Old Jan 26, 2025 | 10:41 PM
Have you checked all your fuses?
Old Jan 27, 2025 | 01:04 PM
Got160s's Avatar
Yes fuses and relays. Everything else seems to check out. my reference voltages are all good my grounds all good. It’s only my VPWR Out of pcm pin B 51,52,53
