2004 f150 5.4L Stalls at low rpms. HELP!!
Old Aug 28, 2023 | 02:10 AM
ErzaAF's Avatar
Hey everyone,
bought my 2004 f150 about 2 weeks ago and noticed it was occasionally stall when idling in gear or at low rpm’s like slow turns.
It doesn’t do it all the time but regardless I need this fixed as I was hoping to make this my new daily.
attempted fixes
- cleaned Throttle body
- cleaned MAF
- replaced VCT Solenoids
I also haven’t properly reset the PCM after doing these as apparently leaving the battery unplugged for 5 minutes doesn’t do it on these vehicles.
any suggestions on what I should do? I truly am at a loss here. Will resetting the PCM help or eliminate the issue?
could it be oil pressure related? I’m currently running 5w-20 but I hear switching to 5w-30 may be the way to go.
Old Aug 31, 2023 | 01:51 PM
P49Y-CY's Avatar
when i first bought my truck (2004 fx4 5.4) i installed a solenoid and phaser. it took me a few weeks and i had the battery out of the vehicle the whole time. after i got it all back together it was doing the same thing you're talking about.
it did it for about a week of driving, but after a while it fixed itself (relearned? not sure)
what i probably should have done is what fordtechmakuloko recommends doing in this video. but, t fixed itself and stopped stalling after a while.
Old Aug 31, 2023 | 08:13 PM
getterdun's Avatar
Need OBD codes. If you don't have a scanner you can take it to a auto parts store and they'll scan it for you and tell you any codes that exist.
Old Aug 31, 2023 | 11:50 PM
There won't be any codes if the CEL hasn't come on since you disconnected the battery.
Old Sep 1, 2023 | 03:19 PM
getterdun's Avatar
Didn't remember that.
.I'd drive it until the problem recurs a few times, then check the codes. It may not set a code the first couple of times.
Old Sep 3, 2023 | 04:06 AM
99F150V6's Avatar
You might need to recalibrate the TBody.
Old Jan 31, 2024 | 11:57 AM
aqua-holic's Avatar
Did you ever figure your problem out? Others may benefit from it.
