P2105 P2107 p2110 codes
Old Jul 17, 2023 | 07:34 PM
Jb84's Avatar
Use to get them every now and then but it’s every time it drove now, any ideas be for I start throwing parts at it, I know certain years had throttle body issues
Old Jul 17, 2023 | 11:10 PM
Please post truck details.
Old Jul 17, 2023 | 11:31 PM
Jb84's Avatar
05 f150 5.4
Old Jul 21, 2023 | 11:55 AM
getterdun's Avatar
Since all of these codes are related to the electronic throttle body, I'd start by disconnecting all of the wiring connectors at the throttle, inspecting them and cleaning them as necessary. I'd also make sure that there's a good tight fit between the air intake snorkel and the throttle body. I'd also inspect the wiring between the throttle and the PCM.
If this didn't resolve the problem I'd disconnect, inspect, and reconnect the PCM wire connectors.
If the problem persists, I'd disconnect the battery and let it sit for about 15 minutes then reconnect it and see if that helps.
Here is a related link: https://www.f150forum.com/f4/p2107-p2110-65188/
Old Jul 21, 2023 | 12:45 PM
Jb84's Avatar
Iv done all that already……
it use to only do it in reverse when given any amount of throttle other than idle in reverse.
now it doesn’t matter what gear it’s in.
this truck has a custom tune on it so idk know if the deal will able to reset the computer, it will not make it to the dealer on the stock tune with it having a built motor
Old Jul 21, 2023 | 02:24 PM
You have to try the stock tune to see if this issue is tune related.
Old Jul 21, 2023 | 03:42 PM
Jb84's Avatar
been on the same tune for the past 4 years
