TPMS sensor relearn.. Need some help
Old Jun 10, 2023 | 02:14 PM
aqua-holic's Avatar
Trying to relearn my TPMS sensors on my 07 Screw 5.4.
Anyone use this learn tool before or done the relearn procedure? Truck goes into learn mode but when i tap the button and put it next to the stem on the driver front nothing happens.
JDIAG TPMS Sensor Tool, TPMS Relearn Tool for F150 Auto TPMS Reset Sensor Programming Training Tools Tire Pressure Monitoring System (TPMS-19 / 8C2Z-1A203-A) https://a.co/d/4doxWAy
Old Jun 10, 2023 | 08:55 PM
You have to press and hold the power button, not just tap it. Also, don't put it right at the valve stem, hold it at the edge of the rim near the valve stem.
How to use TPMS19 sensor tool?
1. Set the car in TPMS learning mode. (car horns twice)
2. Starting relearn process from left front tire, point antenna on correct position. Press & hold power button. Once the speaker chirped, move to the next tire.
3. Follow this order to rest TPMS sensors: Front left, front right, rear right, rear left.
4. After all sensors reset, the car horns twice means TPMS re-learn finished.
So I decided to try this again after it failed to work the first time. This time worked like a charm. You have to angle it correctly. Do not place the programmer at the valve stem. I placed it at the edge of the rim where the valve stem is. I think possibly having it right at the valve stem was causing it to miss the signal. Anyway, highly recommend. Took less than a minute and worked as advertised.
