Intermittent ABS light
Old Apr 15, 2023 | 09:33 AM
Johns331's Avatar
A few days ago my 2006 F 150 showed an intermittent ABS light. The light would come on when I started the truck but would eventually go out. Then it started to stay on constantly, unless I shut the engine off and then immediately turned it back on and then the ABS light wouldn't come on. The truck's brakes operate normally. This has been a good truck that has never broken down or required anything other than normal maintenance in over 105,000 miles of use.
Old Apr 21, 2023 | 12:50 PM
getterdun's Avatar
If you haven't already seen these they may be helpful:
https://www.vehiclehistory.com/questions/why-does-the-ford-f150-abs-light-come-on-130992
https://www.ford-trucks.com/how-tos/a/ford-f150-f250-why-is-my-abs-light-on-356396
Here's a wiring diagram of the ABS system from a 2004 Ford manual
Old Apr 21, 2023 | 06:30 PM
Before looking at wiring schematics, you need to get the ABS code read to see where to start diagnosing.
Old Apr 23, 2023 | 06:17 PM
Johns331's Avatar
Took the truck to Auto Zone and used their free plug in tool. According to the tool, it has a ABS fault or a wiring continuity fault in the rear sensor. When it first started to fault, the ABS light would go out if I turned off the ignition then restarted it. Now the ABS light stays on all the time and will not go out with a restart. The truck has never been in an accident or has it had to traverse deep water, and that leads me to think it's the sensor. I will also check all the connections under the truck to insure there is no corrosion on any of the terminals.
Old Apr 24, 2023 | 12:36 PM
getterdun's Avatar
My 2004 5.4 Lariat had this same problem in the past, got code C1230-E0 (Wheel Sensor Rear Center Input Circuit Failure) replaced rear sensor, and that fixed it.
