Starts once then won't start again
Old Jun 30, 2022 | 06:50 AM
Toleary's Avatar
Hi. I am new to forums so I'll do my best from what I've observed.
I have a 2005 Ford f150 xlt 5.4l v8. 136,000 miles. The truck sat for about a year due to no reverse before I got it and replaced the transmission. Now, was driving down the street one day and the truck just died. It would crank and crank but would never turn over. I replaced the entire fuel tank and fuel pump including fuel lines and filter. Code reader says there's fuel pressure. So, in the morning I'll go out and turn it over and it will fire right up. It runs rough with some pinging noises almost like metal hitting metal and then eventually it will stall out if I don't keep my foot on the gas. After that, the truck will not start, it will crank but won't turn over. I've sprayed starting fluid, put gas in the spark plug holes, still won't turn over. Until the next morning of course. A list of things I've done so far..
Replaced starter (used)
replaced alternator (used)
Replaced ignition coils (aftermarket)
Replaced vvt solenoid (both sides)
Replaced camshaft sensors (both sides)
Replaced crankshaft sensorReplaced 4 injectors (first 2 on each side)
Replaced fuel rail sensorReplaced MAF sensorExchanged out all fusesCleaned throttle bodyReplaced ignition switch I am leaning toward a loose ground somewhere but not sure how I go about tracking them all down. Is there a map of where every ground should be? Battery tested good at the store. I have tried all I could think of. Any insight would be greatly appreciated.
Old Jun 30, 2022 | 09:11 AM
jr105's Avatar
Are there any codes when it runs rough and stalls?
Old Jun 30, 2022 | 09:52 AM
Roadie's Avatar
Did you replace the FPDM?
Old Jun 30, 2022 | 09:58 AM
Toleary's Avatar
No, I cleared the pcm (connected pis + neg cables). I wish it would but it doesnt.
Old Jun 30, 2022 | 10:00 AM
Toleary's Avatar
Yes, bought new one and also tried bypassing it. Got the same results both ways.
Old Jun 30, 2022 | 05:35 PM
Roadie's Avatar
clogged fuel injectors?
Old Jun 30, 2022 | 07:27 PM
You mention fuel pressure according to the scan tool. What is the fuel pressure in psi?
Old Jun 30, 2022 | 08:27 PM
Toleary's Avatar
I removed and cleaned all injectors. Also sprayed air through the rail to make sure it was clear. The fuel psi was 39psi. Which I think is normal?
