Changing #1 bank 1 O2 sensor need help!
IM gasket will sure do that. It's not too heavy a wrenching job. Just that reconnecting the vacuum line from back of IM to the Brake Booster is a pita. But if this ole stove up seventy year old can do it, I'm betting you could too.
When you're ready for reassembly, set the manifold down in place, then **** it up a little and reach underneath it to reinstall the vacuum line. Also pay attention to the routing of the knock sensor wires. They route between the IMRC linkage and manifold.
Got your hand slapped for NOTHIN' didn't you!
And THANKS for catching the VERY IMPORTANT detail I forgot to mention about wire routing.
I was messing around with the vapor cannister purge valve yesterday. I took a line off and sprayed carb cleaner through it and reconnected the hoses. The idle smoothed out and it quit dying . I wonder If that could have caused all this? CEL still on.
