Advise on leveling kit for 2008 F-150 4x4
Old Jan 4, 2016 | 08:28 PM
armymike03's Avatar
I'm looking for a leveling kit so that I'm able to run 35x12.50 R 18. I spoke with one shop and they told me that I would need to run a 6" suspension lift, the other shop that would need a 3" Front spacer with a 1.5" block in the rear. I've noticed that there a lot of options out there between the leveling kit.
What leveling kit would work or option should I go with?
Thank you for your time.
Old Jan 4, 2016 | 09:22 PM
Dog'em's Avatar
Unfortunately there is more to the equation than just lift, it also depends on what type of tire and width/back space of the rim. You can run 35" mud tires with only a level kit if you do your homework.
Stay away from the 3 inch level kits, they will ruin your front end components fast, even the guys that sell them will steer you away if you actually want to drive your truck.
I have had really good luck talking to the guys at AutoSpring, they have a quality product and are pretty decent guys when answering your questions.
Old Jan 5, 2016 | 03:23 PM
armymike03's Avatar
Thank you. I've also heard running a 3" lift in the front will cause my front suspension components to go out a lot faster. I plan on running 35x 12.50 R 18 atturo trail blade MT on the stock 18 rims until tax season.
Any suggestions would help.
Old Jan 5, 2016 | 03:41 PM
pizzaman711's Avatar
You'll most likely need to trim the front valance some and just deal with some rubbing due to them being a 12.50 and a M/T pattern on just a 2-2.5" level. Something a little narrower or shorter would work better. If you go away from stock wheels you'll most likely need to get a 4-6" lift kit as well unless you get wheels with the same spec's as the stock ones.
Old Jan 12, 2016 | 11:34 AM
Jmo371's Avatar
I have a 2.5" front spacer and a 1.5 inch rear block and run 315 70-17's...basically the metric equivalent to a 35x12.50. They only rub in reverse at full lock a touch on the upper control arm
Old Jan 12, 2016 | 02:06 PM
kcward's Avatar
Rancho Quick Lift Loaded's? My truck is level ish...
