Stalling while idling
Old Nov 27, 2015 | 06:36 PM
David Sessions's Avatar
Hi all. I'm new to this and I'm having a problem with my 06 F150 with the 5.4 L triton. I'm having a problem stalling out at an idle when the engine is warm. The engine light doesn't come on until it has stalled out. Then I have a bit of a problem starting it back up after it has stalled. I've changed the fuel filter, one of the fuel injectors, replaced the battery and still having the same problem. Any help or advice on where I should look next would be greatly appreciated! Thanks
Old Nov 27, 2015 | 06:53 PM
Hi David! Welcome to the forums.
How many miles are on your 5.4 L triton?
If it is over 100k, you might want to change the plugs.
What was wrong with one of the injectors? Leaky?
Old Nov 27, 2015 | 07:14 PM
It has 127k on it but I did a tune up about 20k miles ago. I'm not sure what was wrong with the injectors but it was causing my engine to misfire. Figured that would solve my stalling problem but it didn't.
Old Nov 27, 2015 | 07:34 PM
Interesting.
I'm still leaning towards a leaky/problematic injector.
Also a failing FPDM could be causing this issue. They can do funky things when they get corroded.
Old Nov 27, 2015 | 07:56 PM
So would you just recommended checking each injector?
Old Nov 27, 2015 | 09:16 PM
You may have a batch of injectors left over from the 2005 run that were defective and leaky.
DEFINITELY check the FPDM, they are very subject to corrosion.
Old Nov 27, 2015 | 09:24 PM
Dunesgirl's Avatar
BTW, the FPDM stands for Fuel Pump Driver Module. It sits kind of behind/above where your spare tire is if I remember right. It's just a connector, and when corroded, it can cause some weird problems.
Here's what it looks like brand new:
And installed:
Old Dec 27, 2015 | 02:59 AM
Hooah.soldier's Avatar
Start simple. Clean your MAF sensor and air filter. If you are up to it, throttle body as well. It will cost you less than $15 at the auto parts store for the CRC brand aerosols. I had a similar problem and replaced the FPDM, Fuel filter, plugs and never checked the MAF sensor.
Old Dec 27, 2015 | 05:26 PM
08FX4SC's Avatar
And installed:
That thing left me on the side of the road. Had to get a tow truck.
Old Dec 31, 2015 | 10:41 AM
Hawkz28's Avatar
Same thing happened to me a few years back.
I cleaned the Throttle body really well, and it fixed the issue. That was my problem. I would suggest cleaning yours to rule it out.
Old Dec 31, 2015 | 11:46 AM
Just be sure not to touch the throttle plate.
Old Dec 31, 2015 | 03:21 PM
You can touch it, just don't move it. It needs to be cleaned too.
Old Dec 31, 2015 | 03:36 PM
Thanks glc! That's what I meant to say. Ooopps.
