Motor mount ? Misfire ? What the heck ? Help!
Old Nov 2, 2015 | 08:53 PM
YOMAN's Avatar
It gets a bit annoying.
I noticed that my truck starts has quick vibration like 1-2 sec then it's gone it's between 40-65mph. it happens once a while. No wot, just normal driving , not downshift. Only upshift
I feel like I hit rumble strips by side of road.
What's it ??
No engine tool light on.
I'm clues less
Thanks!
Old Nov 2, 2015 | 09:58 PM
Does it do it under light acceleration right after it shifts into overdrive? If so, that's a low grade misfire - plugs and/or cops.
Old Nov 2, 2015 | 10:35 PM
YOMAN's Avatar
Yeah sound like that.
Low grade misfire - what does that mean? Soon to be fail ?
I replaced the plugs approx 15-18k ago
Its now 112k
The cop is original-
Guess try cop first?
Will ford or shop test it for me to see if its low grade misfire or cop is shot? Instead for me to keep guessing ?
Thanks!!!!
Old Nov 3, 2015 | 12:22 AM
Did you use Motorcraft plugs?
Testing the cops is difficult - you pretty much have to troubleshoot by substitution unless you can get it to throw a CEL or you have a scanner that can monitor Mode 6 data.
Old Nov 3, 2015 | 09:55 AM
YOMAN's Avatar
Yup, motorcraft plugs ��
I guess I'll wait for tool/engine light on.
I do have scanner for it (scan gauge II) it's basic cheap one ha.
Jake
Old Nov 3, 2015 | 06:05 PM
Lewissa81's Avatar
When you replaced the plugs, did you replace the COP boots? If not, I would start with those. Think of them like ignition wires. Clean the contact in the cop with a fingernail file, and use a small dab of dielectric grease where the boot spring meets the cop and plug.
Old Nov 3, 2015 | 07:27 PM
No, do not put any grease on the spring - only on the inside of the boot.
Old Nov 3, 2015 | 07:33 PM
YOMAN's Avatar
No i didn't replace COP. Just sparks.
Thank you all for help me out.
Jake
Old Nov 3, 2015 | 10:05 PM
You can buy boot and spring kits for a fraction of the cost of cops.
Old Nov 26, 2015 | 09:55 AM
YOMAN's Avatar
Updated:
I wanted to try cheap way first before dump $250-300. So I put approx 30 oz of Techron Pro fuel injector cleaner, cleaned throttle choke and map throttle and I haven't notice any sudden rumble at all for almost 2 weeks
Hope it is not tempy fix LOL
