Cause of intermitent engine or driveline vibration???
Old Jun 14, 2015 | 09:29 AM
John Mc's Avatar
Guys my '06 5.4 4X4 has an intermittent terrible vibration that will cause the engine to start to run rough - extremely rough. So bad that the truck feels as if it will die. I can't really describe it except to say that when it first happened I thought I had a flat tire, so I can't say it's even in the engine. The trans shifted normally as far as I can tell.
Now here's the weird part: I shut the engine off and after restarting, the truck runs fine. No engine light. It's maddening because it occurs only maybe once a week. Any thoughts on where to start??? Anyone had this issue before???
Old Jun 23, 2015 | 04:08 PM
bjay22's Avatar
Did you ever find the problem. mine is doing the same thing?
Old Jun 24, 2015 | 09:24 AM
2008_XL's Avatar
Did either of you scan it for pending codes? Even without a cel, there could be codes pending that a scan tool will read.
Old Jun 24, 2015 | 09:55 AM
John Mc's Avatar
No, not as of yet. I did clean the Mass Air Flow and it has not reoccurred. I thank you for your response and of course the next logical step is to scan for codes.
Old Jun 24, 2015 | 11:02 AM
2008_XL's Avatar
Clean the throttle body too. How many miles on the plugs, cops and fuel filter? Checking your fuel pump driver module above the spare wouldn't hurt either.
A parts store can plug into your obd2 port and scan to see if there are any pending codes. It's usually free, too.
Old Jun 24, 2015 | 11:52 AM
bjay22's Avatar
My truck has a a code of P0316
Old Jun 24, 2015 | 11:56 AM
2008_XL's Avatar
Do you have a 3v 5.4? Could be the injectors.
Otherwise:
- Faulty Crankshaft Position (CKP)
- Crankshaft Position (CKP) sensor harness is open or shorted
- Crankshaft Position (CKP) sensor circuit poor electrical connection
- Ignition System
- Fuel Injectors
- Running out of fuel
- Fuel Quality
- Faulty Engine Control Module (ECM)
Old Jun 24, 2015 | 01:36 PM
IR0NS1N's Avatar
P0316 is misfire on startup. Probably time for new plugs and coil boots.
