help!
Old Apr 5, 2015 | 10:03 PM
dagger79's Avatar
help!
Newbie! First post!
Was working in the drive way today. Had my 4 ways on for two hours cause the nose of my truck was on the street. Went to start the truck.. Sounded like dead battery.. Then nothing.. Now click no lights. Like no battery hooked up.
Any ideas?
TIA
Old Apr 5, 2015 | 10:08 PM
RevBiker's Avatar
just recharge your battery, everything will be ok.
Old Apr 5, 2015 | 10:15 PM
dagger79's Avatar
Had a charger on it cor a few hours and nothing.. When i tried to boost it i got no lights or anything.. Put a diff battery in and it sparked like crazy and battery wire got stuck to terminal..
Old Apr 6, 2015 | 12:01 AM
You sure you didn't hook up the other battery backwards?
Old Apr 6, 2015 | 08:34 AM
dagger79's Avatar
Possibly.. Was dark and i was frustrated! Lol
Old Apr 6, 2015 | 10:16 AM
If that's what you did, who knows what damage that may have caused.
Old Apr 6, 2015 | 10:48 AM
Hawkz28's Avatar
Wow, you arc welded it to the terminal! Your lucky you didn't explode!
Take all that crap out, clean it up, and make sure you can see what your doing.
Sounds like you almost had a dead battery turn into a Darwin Award.
Old Apr 6, 2015 | 07:29 PM
RevBiker's Avatar
hopefully all ya did was blow some fuses. WOW scary stuff! Also check the battery charger you were using to recharge the dead battery from 2 hrs. of 4 ways. put a volt meter on it!
Old Apr 6, 2015 | 09:38 PM
Has it ever occurred to you that automotive repair might not be your calling.....
