No Windows Will Roll up or Down
Hell all
2005 F150 super crew 4x4. 5.4l
No windows will roll up or down. This includes from the drivers door buttons or the individual door buttons.
Hope someone can help.
Thanks for the response. I should have clarified that in my post. Yes, I changed the fuse with no luck. The fuse #is 401, 30 amp.
Any other suggestions?
I just dread the thought of bringing it to the dealer.
I had the same problem about a year ago. I found it was the ground wire in the wire harness of the drivers door.
I changed the fuse, cleaned the contacts and that didn't fix it. Someone on here recommended I check the wires.
Here is what I did to test, I would hold the button down to drivers window and while I would squeeze and move the wires around, by doing this I could get the window to move up & down a few times.
The hard part was finding the wire, I was able to roll the harness boot back onto itself and find the wire that was broke, the harness was the only thing that held it in place allowing the copper to make contact from time to time.
I spliced in a new section of wire and have had no problems since.
I hope this helps, Good Luck.
