08 F150 4.6 Aftermarket Exhaust
There are a ton of options for your truck as far as bolt on systems go. If you're looking for something that sounds good when you put your foot down, but you can drive home from work without getting a headache there are a few options that are really designed specifically for that.
You can check out all the options on the link to our site here:http://truckyeah.com/2008_ford_f150_...2158&cid=10121
The ones we would suggest looking at would be:
Corsa
Flowmaster Force II
Magnaflow - Lots of options
MBRP XP Series
Corsa
Flowmaster Force II
MBRP XP Series
Borla! Once you go borla you'll never go back. If you keep factory cats, it won't be overly loud. I cut mine out to see what it would be like, a bit too much on the loud side. Going to be installing high flows soon.
Xr-1s are a great muffler.
Corsa
Flowmaster Force II
MBRP XP Series
Corsa
Flowmaster Force II
MBRP XP Series
http://www.summitracing.com/parts/wl...rd/model/f-150
If your shopping by price it's a decent system, but we have heard of people having issues with installs. That same rear exit style is available from Magnaflow which uses higher quality stainless and comes with a lifetime warranty versus the 90 days the Dynomax system does. We would be happy to get you a deal on the Magnaflow system too.
Thanks, John
John,
Here is the link to the dual rear outlet system: http://truckyeah.com/magnaflow/magna.../i-487253.aspx
We can probably do around $625 shipped depending on where you're located. Let us know if there is anything else we can help with.
Eric
Eric
