My truck's in ICU
Old Aug 28, 2014 | 02:01 PM
xrider's Avatar
Originally Posted by SoonerTruck
Hopefully you didn't take my comment the wrong way. It was tongue-in-cheek because of the fact that you have to replace the entire engine instead of just a few inexpensive parts.
In any case, here's a broad primer:
VCT Solenoid receives command from the ECU and controls the flow of oil to the cam phasers. The VCT's actually limit the flow of oil to certain passage ways to the cam phasers in order to advance/retard the cam timing on each side of the engine. The cam phasers are linked to the engine mechanicals via the timing chain and do the physical work of changing the cam timing. VCT solenoids can be changed out without too much fuss, Cam phasers are a much more invasive item to replace. If the VCT solenoids go bad, you throw trouble codes and the engine runs poorly, but will still function albeit at reduced performance. If the cam phaser has a failure/blockage, it could cause much worse symptoms in extreme cases, but usually just causes the infamous cam phaser diesel-clattering. In your case, the failed lifter was much more damaging to engine internals, including the camshaft.
Thanks for the response. It helped me understand the correlation of the cylinder head parts.
Old Aug 29, 2014 | 10:46 AM
pethel's Avatar
Funny, I just thought it was a bad case of cam phaser failure and haven't been too concerned.
However, It did "tick" alot louder and meaner than my Green '04 ever did though. That truck just "clattered" on both sides for more than 75K miles.
Who knew
Old Sep 18, 2014 | 06:54 AM
pethel's Avatar
Today is the day! Well today I finally get to drive my truck once again. I bought a used engine from a Salvage yard, supposedly with 36K miles on it. My shop got it installed and started yesterday. He said it idles and sounds great. He went ahead and changed the plugs and did an oil change for me.
However, in the process they broke a little clip on the tranny linkage or something so they ordered that little part and is gonna install that this morning. Once he installs that, he's gonna take it out for a drive to be sure everything is running right.
He said he'd call me to come get it.
So glad this is almost over and I and my truck can move on.
Old Sep 18, 2014 | 12:30 PM
Good luck with the new power plant......
Old Sep 18, 2014 | 01:27 PM
pethel's Avatar
Thanks! Jeff still hasn't called me to tell me to come get it. My lip is starting to poke out again.LOL
Old Sep 18, 2014 | 06:50 PM
pethel's Avatar
Big smiles and a frown.
Been driving all afternoon. WOW what a difference a motor can make.
I had no idea my old motor was hurt that bad. This one runs so smooth and is perfectly quiet at idle. Solid power again too!
Now for the frown This truck has been tough on my wallet this summer.
-Used 36K mile engine=$2200
-engine install=$1800
-new plugs, oil change, tranny cable, serpentine belt, ect,ect. =$350
-new throttle body=$300
-new Magnaflow catts (installed)= $500
Thats $5150 bucks Jeez
I should be good for awhile though.
Old Oct 13, 2014 | 02:30 AM
renegade734's Avatar
Same thing happened to mine at 116,000 miles, with the added bonus of a fractured camshaft. You got off cheaper than I did ... just under $8000 for a crate motor installed.
Runs like a new truck now. Feels good, doesn't it ?
Old Oct 13, 2014 | 08:12 AM
pethel's Avatar
Yeah, I couldn't swing the crate motor option. But I think (knock on wood) that I got a good used motor. It was back in the shop again last week. The motor had an exhaust leak between the head and manifold. My buddy fixed it at no extra charge.
Now, it purrs like a kitten.
I might just drive this thing for a few more years and get my money out of it before I trade up.
Old Oct 13, 2014 | 11:03 AM
Not all that surprising considering what the new engine has probably been through -- a major accident of some kind, yanked out of one truck, transported to your mechanic at God only knows what angle, picked up and dropped into another truck! That's a lot of twisting and turning and grabbing that an engine doesn't normally go through!
Old Oct 13, 2014 | 12:52 PM
pethel's Avatar
You're probably right. It ran pretty quietly for almost a week. Then it started ticking louder and louder from the passenger side manifold. If knelt down by the front tire you could see/hear where it was coming from. Once removed we could see by the black exhaust residue that it was actually leaking from two spots on the head. And, it didn't want to seal very well to the exhaust. We ended up using my old manifold from my old engine. It mated up nicely with the head and the exhaust.
I've got my ears tuned for any kind of noise at this point. After all I've been through with this truck, I'm pretty sensitive to ticking sounds right now. LOL
Old Jun 13, 2015 | 10:14 AM
pethel's Avatar
Update! I dug up my old thread to report that it turned over 10,000 miles this past week since the heart transplant.
The donor engine is still running flawless.
KNOCK on wood!
Old Jun 13, 2015 | 10:37 AM
Hawkz28's Avatar
KNOCK on wood!
Sounds good. I hope that this doesn't happen to me! I have 110k on a 2006, runs like a champ still doesn't even use any oil between changes.
I read the post, looks like you made out with that engine, what you paid seems really reasonable for the parts and install. Less than 2k for install? Wow, I bet the dealers around here charge 5k labor, spark plugs alone are $700!
Old Jun 13, 2015 | 08:45 PM
pethel's Avatar
It really changed me. Now I when I drive, I listen for every little odd noise and check my fluids too often. LOL
