2009 Sync installed in a 2005
The BCM and ECU are not directly wired in to the radio because they are typically on the HS-CAN Bus. The ICM is the gateway between the HS-CAN and MS-CAN networks in many vehicles but not the F-150. This is the reason the Clarion navigation will not fire up.
A simple review of the Ford wiring diagrams will show you that it will not work. Specifically Section 14. I'm confused as to what repinning you want to do, as the few things the Clarion needs to operate are already in the correct pin locations. There is just no messaging to make the Clarion run.
I don't want to see you waste your time or money - not trying to give you a hard time
