Opinions? Feedback?
Old Aug 18, 2013 | 10:15 AM
87ttopstang's Avatar
Opinions? Feedback?
Has anyone used this kit or know anyone that has? Or a similar kit?
LINK
Old Aug 18, 2013 | 08:20 PM
Pockets's Avatar
Looks like a major pain in the a** and way to expensive .... you could do it right without those extra control arms and just a 2.5 inch spacer .... you don't want to go too far because then your angles will be messed up
Old Aug 18, 2013 | 08:23 PM
pizzaman711's Avatar
I've never seen any 04-08 kit that uses extended control arms like that.. So I wouldn't do it. If no major brand does it, chances are there's probably a good reason. Besides 3.5" is way too much without a drop down crossmember. The extended arms may help some but even then your angles would still be terrible. I'd do it right and stick to a 2.5" level at the max, or if you want more get a 4" or 6" suspension lift or 3" body lift.
Old Aug 18, 2013 | 09:15 PM
jdruzik's Avatar
I'm not a fan of nylon spacers... 3.5 inches is to much for a leveling kit as has been mentioned. Stick with 2inches or 2.5 at the most. This will save you from future grief...
Old Aug 19, 2013 | 01:19 AM
Just realized they said those are uni-ball upper control arms too.. So leveling kit, blocks, and uni-ball a-arms for under 400? Something definitely isn't right with that kit.
Old Aug 19, 2013 | 09:31 AM
Thanks guys. I figured it was odd.
