Oil Leak Passenger Side
Old Jul 12, 2013 | 05:32 PM
ak_cowboy's Avatar
I've got an oil leak on the passenger side of my 2007 F150 5.4.
I don't believe it's the oil pan, since the front of the motor is getting wet. I'm hoping it's just the Valve cover. The passenger side of the alternator is damp, but not the drivers. I believe it's getting flung around by the belt. But it's also dripping back and covering the front diff and oil pan.
I cleaned it all up and haven't been able to see any major leaks, it also only leaks right after driving, then slows down or stops after sitting a while.
Here are some pics
[URL=http://s1115.photobucket.com/user/ak_cowboy/media/2007%20F150/Oil%20Leak/2013-06-25_20-10-03_573-1.jpg.html]
Old Jul 14, 2013 | 02:36 AM
ak_cowboy's Avatar
Nobody has had this problem?
Old Jul 14, 2013 | 08:15 AM
jaws12's Avatar
No, but I suggest taking the fender well out and cleaning the engine very good. Then let it run in park while you search for the leak. Maybe you will see the drip more easily.
Old Jul 14, 2013 | 03:56 PM
08FX4SC's Avatar
Front Cover?
Old Mar 7, 2021 | 10:38 PM
Hpsportsfanatic's Avatar
Any luck on finding out?
My 2006 f150 seems to be leaking in a similar spot. Any luck on figuring it out?
