Stock wheels and a 6" lift kit
Old Jun 25, 2013 | 12:18 PM
Glen Smith's Avatar
Quick question can I use stock 20" fx4 wheels on a 4x2 with a 6" lift I'm looking to lift my 06 screw this fall and would like to keep my fx4 wheels and just add larger tires could I use spacers on the wheels to get enough off set or do I need to buy new wheels thanks
Old Jun 25, 2013 | 12:35 PM
pizzaman711's Avatar
You could get the skyjacker kit which says it works with stock wheels. But I think you may be limited in your tire sizes because of how far the stock wheels tuck in. So you may have to get new wheels with the proper offset, or I guess if your feeling lucky go the wheel spacer route.
Old Jun 25, 2013 | 12:44 PM
Glen Smith's Avatar
Thanks was looking into the fab tech lift
Old Jun 25, 2013 | 02:20 PM
Fabtech will work with stock wheels and stock size tires, but bigger, wider tires will cause some rubbing issues on stock wheels.
