E brake rubber plug fell through
After I had adjusted my e brake, the rubber plug fell though and is stuck inside on the real wheel. I tried forever, but it seems like without taking the rotor off, there no accessing the iside if that parking brake drum. Will this cause any issues? I found another way to seal the hole where the plug was for now.
And why can't you take the rotor off? It's just 2 bolts to take the caliper off. I've taken mine off to clean them and to make sure everything looks good on a yearly basis.
I'm confused.
I'm confused.
It's not that I can't get it off, I'm just being lazy haha. I drove it, it's fine. I'll just leave it in there until I take it off at some point.
Haha yeah right. Considering the rear brakes do about 20% of the work, it wouldn't get hot enough.
I don't see how that is necessarily corollary to the heat produced. The rear's do 30% of the work, and are undersized compared to the fronts for that reason. The heat produced will not likely be as high as the fronts, but I wouldn't doubt it is still enough to melt rubber at times.
