'04 SCrew Intermittent Shake
Old Apr 7, 2013 | 11:05 AM
racruise's Avatar
'04 5.4 SCrew 4X4 automatic. 90k. Has intermittent shake- coins flipping in the ashtray type-. Other than a leveling kit, truck is completely stock including tire size.
Does not shake on every drive.
Usually occurs within a few miles of a cold start.
Speed sensitive only to the fact that the faster you go the worse it gets but shakes at all speeds.
Shakes regardless of throttle position/gear.
Stop put in park & shut it off, then right back on- no shake.
There are a ton of shaking threads, but I cant find one with similar issues, any help is appreciated. Hopefully some one else has seen this and can give me a direction to start looking in. Right now I'm leaning toward something in the drivetrain, but keep in mind I'm an electrician not a mechanic.
Old Apr 7, 2013 | 11:49 AM
Need to rule out misfires. Have the spark plugs ever been changed? If not, they are overdue.
Old Jun 14, 2015 | 09:51 AM
John Mc's Avatar
Did you ever find out the issue here??
I have EXACTLY the same problem. Love to know your solution, thanks!
Just had new plugs put in, the problem remains. No difference.
Old Jun 14, 2015 | 11:24 AM
I doubt you will get a reply, that is the member's one and only post and it was over 2 years ago.
