B1681 pats
Old Mar 25, 2013 | 12:04 PM
Tellez10's Avatar
B1681 pats
04 f150 5.4 4x4 crew cab new stile
I have an small accident mainly on the suspension I have it replaced but now it won't crank .
I put the key on the switch , won't crank but I heard a click on the fuse box
Everything works , lights , windows ,I heard fuel pump working , I just have the starter connected to the battery , and it cranks , had new battery on it , I did run quick scan to it and it give me 3 codes , b1681, and 2 abs codes , I check all fuses , everyone looks ok , I'm just trying to save some money. ..tow truck and ford diagnostic , anything that I can try before get it towed to the dealership ? Thank you
Old Mar 25, 2013 | 12:58 PM
mdhawkin's Avatar
Code reads as no read from transceiver in PATS system. Not sure what was damaged in accident but this would explain why its not starting from ignition. Do a google search if you have a moment, you can probably find wiring diagrams and more details. Limited on time sorry for no more info, I will see if I can get more when time allows.
Old Mar 25, 2013 | 02:18 PM
Only one post per subject allowed so had to remove the other post. Thanks
