Battery problems. Possibly altenator?
Old Mar 15, 2013 | 04:49 AM
code58's Avatar
=tbear853;4964687Yeah, lucky for sure.
Not all forms of damage are going to be immediately evident either.
Electrically speaking, either way when the first cable is pulled loose from the battery terminal, no matter which one it is .... the battery is out of the system and that's when you get spikes if the alternator is running.
Many years ago (I think about 1987) when I worked for a BMW dealer we were told to never jump a dead battery in one of the Bemmers because the jump could cause a spike that would take out a VERY expensive PCM. We ALWAYS disconnected and charged, never jumped.
Old Mar 15, 2013 | 05:06 AM
code58's Avatar
Originally Posted by 6Jeff6
If it has slowly gotten worse my money is on the alternator. Batteries usually just crap out quick and when its the alternator it slowly happens because battery holds on for awhile. And 14.3 is
low if his battery was low it should've been aking for a full charge. But batteries can do weird things make sure you test all cold and hot as that makes a difference on both too.
If a voltage regulator is "set" for 14.3-14.5V,(they're not adjustable, the voltage is "built" into it) no matter how dead the battery is it's not going to go above that. You're not going to see 15 or 16V no matter how dead it is. And also, batteries DON'T "usually crap out quick", they only SEEM to. Most batteries decline slowly over about the last year and a half or more before they die. I load test all my batteries about every 3 month at least and you can always see the decline as the battery ages. I would say I have seen decline as long as 2-2+ years until the battery is down to about 12V or so before I replace it. Full charge new should be AT LEAST 12.6V and some used to be as high as 12.8V. By the time they reach 12.0 V, the ice you're skating on is getting a little thin. It's just that 12V batteries don't normally show the decline in starter speed the way 6V batteries did. You "think" they "just crap out",but that's rarely how it actually happens according to Mr. Tester, 1st. name Load.
