edge tuner, now auto truck belt squeels when shifting???
Old Mar 9, 2013 | 09:32 PM
joey_espo's Avatar
my truck (05 5.4) never had any mechanical issues and sounded great, now i put the edge programmer on (level 3) and under full acceleration when it goes to shift from 1st to 2nd my belt sounds like its spinning / squealing....does this mean time for a new belt? or any common issues like this with anyone else that added a few hp from stock?
Old Mar 9, 2013 | 09:33 PM
So did mine. Goodyear Gatorback accessory belt is the solution.
Old Mar 9, 2013 | 09:39 PM
joey_espo's Avatar
so i guess the edge does add a few hp if its causing the belts to all of a sudden squeel like that (assuming the increased rpm?)
Old Mar 9, 2013 | 09:48 PM
joey_espo's Avatar
all of my local stored have dayco, and cross reference to dayco brand..even auto zone..who sells the gator back ones?
Old Mar 9, 2013 | 09:50 PM
Well I got mine from autozone but that was a few years ago.
Old Mar 9, 2013 | 09:54 PM
joey_espo's Avatar
looks like its part 4061020 6rib and 102 length, looks like i have to order one vs. picking one up tomorrow :/ summit wants over $40 but amazon has it for $23
Old Mar 9, 2013 | 10:17 PM
MDK's Avatar
MDK
It's all about the Gates belts. Handles my blown F150 and my Cobra with no squeaking and that's temps from -10F to 100F here in CO. Will never use any other belt.
Old Mar 9, 2013 | 10:32 PM
It's not the added HP, it's the quicker shift. Engine is changing RPM almost instantly.
Old Mar 11, 2013 | 01:56 PM
Ace85's Avatar
Its nothing to worry about unless you want the new belt. Mustang Gt's will make that noise stock.
Old Mar 12, 2013 | 12:37 PM
mkosu04's Avatar
its not HP
its shift hardness.
You can adjust the shift hardness in the custom settings on the edge programmer. Reducing the shift hardness would reduce the belt squeal.
Old Mar 12, 2013 | 01:06 PM
to sum it up....engine load transfer between the shorter shifts....
