Help ASAP, anyone use 1 1/4 Leveling on Bilstein 5100 struts
Old Mar 9, 2013 | 02:04 PM
brykwil's Avatar
Installing RCX 6 inch lift,Bilstein 5100 struts, not sure if I should install my 1-1/4 leveling kit! Anyone run this setup that could put my mind at ease! If you have this setup did you install Add A Leaf 1.5/2.0 inch to sit level! This is what I will do unless someone can tell me it's not the way to go!! Thanks for the help!
Old Mar 10, 2013 | 02:18 PM
brykwil's Avatar
No one,,,,ok, I will go with this's setup and see how it turns out! I will post picks when completed!!My only concern is A-Arm angles! I guess I can just pull the 1-1/4 leveling kit off!
Old Mar 10, 2013 | 02:24 PM
pizzaman711's Avatar
Do you have the bilsteins already cranked for the 2"? Are you trying to basically get 3 1/4" on top of the lift? Because if that's what your trying to do, it's an horrible idea. Your angles will be crazy.
Old Mar 10, 2013 | 03:22 PM
brykwil's Avatar
Ya, there set for the six inch lift,top notch! I searched online and some were running this setup and some said not too because RCX drop downs are only 5 inchs!I was hoping that some one on this forum that has this set up would post pics of A-arm angles! If no one posts any pics I will install them see how it looks take some pics and uninstall if necessary! Little bit of extra work but I will know for sure! Thanks
