Idler and Tensioner bearings
Just replaced my 2 idler bearings and the belt tensioner bearing and WOW what a differance. I knew 1 was bad but thought i'd do them all anyway. 30 min job. Bearings press in and out no problem. I used 6203 *** bearings and they were only $6.00 Can.
Did some reading but couldn't find much on just the bearing replacement.
FYI ....
I also had the "whine" or "Whistle" at about 1800RPM when cold and it seems to be gone now. Read some people thinking it was the alternator and I think they may be right. Out today and it was a cold morning and no noises.
When i did my 06 i just did billet pulleys....little bit spendy but looks better....
Link>>> https://www.f150online.com/forums/20...y-install.html
Just replaced my 2 idler bearings and the belt tensioner bearing and WOW what a difference. I knew 1 was bad but thought i'd do them all anyway. 30 min job. Bearings press in and out no problem. I used 6203 *** bearings and they were only $6.00 Can.
I had the same whistle on my 2005 and the dealer was never able to fix it under warranty. Shortly after the warranty ran out and I'd had enough, I replaced the alternator. Problem solved. Never got any money out of them.
Just get the mustang set for the 4.6 3v
http://www.metcomotorsports.com/prod...rod=MIP%2D2005
Search around other sites will be cheaper
