2004-2008 Alternator Replacement w Pics
Old Apr 17, 2013 | 11:12 PM
pmason718's Avatar
Originally Posted by MikeyDubs
Great write up!! I just have a few questions. With the belt tensioner do you just use a ratchet on it to loosen up the tension on the belt to get it off the alternator then when you put the new alternator back on do the same? You don't have to loosen or tighten the belt any right? Sorry not too familiar with this stuff but would like to know so when and if mine goes I can do it myself. Last when can you get a oem alternator from just the ford or somewhere else? Thanks!!
Great question I'm curious to know as well
Old Apr 18, 2013 | 02:08 PM
Nice write-up -- but hopefully I'll never have to use it.......
Old Apr 21, 2013 | 11:47 AM
CJB XLT's Avatar
Ratchet is just to loosen the tension on the belt so it can be removed. OReilly carries some Ford OE parts.
Nice write up!
Old Apr 21, 2013 | 12:14 PM
You aren't turning a bolt, you are using the ratchet or breaker bar in a 1/2" square hole in the tensioner to swivel it against tension.
Old Apr 22, 2013 | 07:28 AM
MikeyDubs's Avatar
Yea that's what I was wondering. So basically that just loosens some of the tension so you can pull the belt off the alternator and you would do the same when you put the new alternator in?
Old Apr 22, 2013 | 01:48 PM
Exactly. In fact, pull the belt out and inspect it carefully, replace if necessary. Belt routing should be on a sticker under the hood.
