Anyone with 2.5" front and 2" rear leveling kits?
Old Feb 4, 2013 | 01:21 AM
DallasSuperCru's Avatar
Question Anyone with 2.5" front and 2" rear leveling kits?
I just wanted a half inch rake up front so I ordered 2.5" front and 2" rear blocks.
Does anyone else have this setup?
If so, would you post pics of how your truck sits?
Thanks!
Old Feb 4, 2013 | 01:52 AM
My truck is a 2WD btw.
Old Feb 4, 2013 | 10:37 AM
shifty219's Avatar
I have a 3inch level up front and 1.5 lift block with 1 inch shorter shackle in the rear (in this pic). Im 4x4 but should be almost the same
Old Feb 5, 2013 | 11:18 PM
Your truck looks great and sits pretty level. I'm hoping my set up would look as good!
Old Feb 6, 2013 | 10:37 AM
twelch2300's Avatar
Ive got 2.5" lvler up front and a 4x4 back in the back which is about 2" ill try to take a better pic today.
Old Feb 6, 2013 | 09:32 PM
Zorro13's Avatar
Hey guys (and gals), new here and enjoying the posts. I have a 2010 F-150 2WD Super Crew, was thinking about a Ready-Lift 3" leveling kit for front and I guess blocks for the rear. Anybody tried this brand or any other that works good. I was considering bagging the rear to help when pulling my car trailer. When attached, it drops the truck 2" in rear. Thought bagging would maintain good ride while still keeping truck level. Any thoughts?? Thanks!!!!!!!!!
Old Feb 6, 2013 | 11:07 PM
So you still have a half inch rake up front right? That's what I'm hoping to achieve.
Old Feb 7, 2013 | 12:53 AM
mikemilo's Avatar
rough country 2.5" front 1" rear
Old Feb 7, 2013 | 11:36 AM
hmfic's Avatar
I have a 2" A.S. Leveling Kit in front with a Skyjacker add-a-leaf in the rear, which netted me exactly 2" of rear lift on my current truck.
On my old 05 FX4 I had the same setup with a 2.5" A.S. in front.
Pics are in my gallery.
Old Feb 10, 2013 | 01:50 PM
Hmmm I wonder if I should've gone with 3" kit. Oh well, we'll see how this turns out when installed. I just got the 2.5" front and 2" rear blocks in.
Old Feb 10, 2013 | 02:02 PM
06yz250f's Avatar
You don't want 3" in the front, stick with what you have.
Old Feb 14, 2013 | 10:53 PM
Thanks!
My truck is 9 years old. The indy mechanic tells me to replace the shocks all around when putting the leveling kit in. Is that necessary precaution since the shocks are that old?
Old Feb 14, 2013 | 11:45 PM
06yz250f's Avatar
If they're the originals, i'm assuming they are well worn out so now is the time so you aren't paying labor on it twice.
Old Feb 15, 2013 | 12:01 PM
Would this work?
http://www.ebay.com/itm/350663927154...=p5197.c0.m619
Since they're going to be stretched >2", I don't want to get a regular set if a longer one is recommended.
Old Feb 15, 2013 | 01:36 PM
06yz250f's Avatar
You shouldn't need new coils, i'd personally go for a better quality shock. Monroe isn't bad, but at nearly $300 you have more options.
For the front, stock shock/strut length is needed. For the rear you can use a stock length or look for a slightly longer but most rear shocks I see are for 0-2" lifted trucks.
