Changed fuel filter......YUCK
Old Feb 3, 2013 | 10:27 AM
BlueLineFX4's Avatar
I bought my 2005 Scab FX4 in early October. I just rolled 60,000 miles and decided to change the fuel filter. I'm absolutely amazed at how dirty the gas was that came out. It runs much smoother now and has a little better response!!
http://www.flickr.com/photos/92244255@N03/8441618124/http://www.flickr.com/photos/92244255@N03/8441618124/ by http://www.flickr.com/people/92244255@N03/, on Flickr
Old Feb 3, 2013 | 02:48 PM
RANGERansom's Avatar
Ouch!! I change mine every other oil change. It still had the factory fuel filter on at 27k, my ranger still had the factory fuel filter on it at 92k.. its so easy to don I dont know why more people dont do it!!
That is some nasty gas ol' girl was sippin on!!!
Old Feb 3, 2013 | 02:56 PM
The previous owner obviously never changed it. It is very easy and ill be doing it much more often! I've been add Techron as well. Hopefully that will head off any early problems!!
Old Feb 3, 2013 | 08:17 PM
Fx4-Michael's Avatar
I changed mine at 75k when I bought my truck and yeah it looked like that... At least you know it works because the other side was clear gas coming out on mine lol
Old Feb 4, 2013 | 03:53 AM
04f150owner's Avatar
i replace mine every 10,000 miles which is about once a year. just changed mine yesterday as a matter of fact. easy to blow through, so the gas i'm getting isn't to bad. make sure when you fuel up there isn't a tanker truck there or one that just left, it stirs the sediment up in the in ground tanks and put in your gas tank by the pumps.
Old Feb 4, 2013 | 04:04 AM
I will definitely be doing mine once a year!! When I was little my Dad always said the same thing about the tanker trucks and it has stayed with me. If there's one there I drive right by.
I'm amazed at how easy it was to change. My only problem with the whole thing was the gas I got on my clothes. Impossible to get out!!!
Old Feb 6, 2013 | 09:17 PM
A DuB's Avatar
I bought my truck used, and mine looked the same. Poor fuel pump!
Old Feb 7, 2013 | 10:30 PM
scheer89's Avatar
I heard the tankers stir up the water vapor too which can mess with the truck??
Old Feb 8, 2013 | 09:02 PM
MTM Ford's Avatar
Might want to check the TB also and make sure it's not gummed up. It's not hard to do either, takes about 20 minutes from start to finish.
Old Feb 8, 2013 | 10:54 PM
Ok, here comes my lack of knowledge...TB???
Old Feb 9, 2013 | 01:17 AM
TB=throttle body
Also clean the maf=mass air flow sensor
Use the appropriate cleaners...
This is every 20k from the gas stations around here.....
Old Feb 9, 2013 | 09:07 AM
pethel's Avatar
I usually change mine about twice a year or after 3-4 oil changes. I also like to blow through it after its removed to see how bad it was. It's amazing how clogged up they get but most of the time the truck still runs.
One more thing I learned a few years ago that If you run your truck out of gas you had better go ahead and change the fuel filter. The next day my truck wouldn't run due to the filter totally clogged from settlement in the bottom of the tank.
Fuel filters are so often overlooked and so easy to change.
Old Feb 9, 2013 | 10:42 AM
Originally Posted by 88racing
TB=throttle body
WOW!! Thanks 88racing. I'm sure there is plenty on here about how to do that. Now I have something to do today!! Ha
