Removing FRAM Oil Filter
i would say its not the fram filter that caused it to be hard to get off. it was it idiot at walmart that over tightened the filter and probably didn't lube the oring. fram is also a cheap oil filter and i don't recommend using them. i personally use mobile 1 5w-20 oil with a mobile 1 oil filter. the filter cost a bout 14 bucks
I know it being FRAM wasnt the problem, it was whoever put it on. Just rediculise.
Yep, my 2008 Passat 2.0T is really bad about that. Even after long trips- for several hours -in the winter, I still have mayo under the oil cap. It's normal for that engine and just the result of tighter emissions controls and the PCV systems on today's engines.
