Speedometer Problem?
Old Sep 18, 2012 | 09:34 PM
KR4Life's Avatar
Question Speedometer Problem?
Hey ya'll, I am a new member here and this is my first thread. I have a 2005 F150 King Ranch that has a speedometer issue. All the gauges work, except occasionally when I decelerate the speedo wont drop below 40 or 50 mph. After sitting for a while (vehicle off) it sometimes drops to 0. Problem is when driving and it stops at say 50mph, this becomes my start point. So, when my speedo says 100mph I am actually doing 50mph. I pulled the cluster and spun the needle by hand with no resistance. Put it back in and no problems for 1 day. Today...same problem. I dont know if its a speed sensor or the cluster going bad. I want to avoid the dealership if possible and fix it myself. Any help would be greatly appreciated! Thanks
Old Sep 19, 2012 | 10:46 AM
sam1947's Avatar
You may have no choice but to go to the dealer for a diagnosis. If it turns out to be the cluster try to find one in a bone yard..even then you will have to see the dealer to have the cluster 'married' to the truck's PCM.
Old Sep 19, 2012 | 11:30 AM
Dealer is going to be your only option for this issue....
Old Sep 19, 2012 | 08:59 PM
KR4Life's Avatar
Thanks for the tip. Found a well respected mechanic who has seen this numerous times before. He said he pulls the cluster and sends it to a automotive electronics shop in Flint, MI that repairs the clusters for about $250. Gonna give it a try. Thanks again!
