Need help with 4wd actuator...
Old Sep 12, 2012 | 01:59 PM
JasonS1's Avatar
I have been researching and have come to the conclusion that I need to put on new 4wd actuators.
Problem:
Metal sound when in 2wd, goes away in 4wd. Sounds like I am dragging a piece of metal. Sounds like passenger side
2005 Ford F-150 FX4 5.8 V8 4WD
Here is what I have done so far for troubleshooting:
1. Put truck in 4wd - sound goes away, hear and feel clunk on drivers side when engaging
2. Replaced solenoid - same result
3. Tried bypassing solenoid - same result
4. Unplugged vacuum lines from solenoid - noise goes away
From what I have done, do you suggest that the Actuators are bad? I will replace both if I am going to be doing it.
I am looking at part numbers 7L1Z-3C247-A for OEM and 600-105 for OEM replacement. Which do you suggest?
Jason
Last edited by JasonS1; Sep 12, 2012 at 02:16 PM. Reason: Added model and year of truck
Old Sep 12, 2012 | 02:59 PM
SoonerTruck's Avatar
Have you checked the vac lines for leaks? If it still does it while bypassing the solenoid, I would be looking for vac leaks, then finally at the actuators themselves.
Old Sep 12, 2012 | 04:41 PM
JasonS1's Avatar
I will try checking for leaks next.
When bypassing the solenoid I was still getting the sound.
But when I leave the vacuum line loose, and unconnected, the noise goes away. So, I guess it is keeping the actuators locked into the hub since there is no vacuum...right?
So, hopefully it is just a vacuum leak that is preventing the actuator from pulling all the way back and is hitting teeth in the hub.
Sound right?
Old Sep 12, 2012 | 10:35 PM
jebrs2's Avatar
Did you try a vacuum check on both actuators? That's how I found my problem, had the same symptoms. Ended up replacing both. There is a ford dealer parts warehouse out of Florida that will sell the actuators for $85 each.
Old Sep 16, 2012 | 08:29 PM
60DRB's Avatar
Old Sep 17, 2012 | 11:55 AM
2stroked's Avatar
Sound right?
Yes, the IWE's lock when there is no vacuum. So what you most likely have is a vacuum leak somewhere leading to partial actuation. Keep in mind though that a partially engaged IWE will eventually grind itself up, so if you've been grinding for a while, fix the vacuum leak, then check the IWE to see if it's wiped out.
Old Sep 18, 2012 | 01:49 PM
a.desisto's Avatar
Don't forget to check the solenoid on the fire wall. As said before if it grinds too long you'll need a new actuator and maybe a hub.
Old Nov 24, 2012 | 10:50 PM
tanner_corley's Avatar
any luck with the problem? i just got done installing a lift on my truck, after cycling through the 4wd it start making a noise like gears tryig to engage. i googled it and narrowed it down to the IWE or the soleniod..
Old Nov 25, 2012 | 12:07 AM
04f150owner's Avatar
i had mine making the same noise, took it into the dealer a few years ago while it was still under warranty. they replaced the solenoid on the firewall. about a year ago i was having problems with my 4wd not engaging fully and would pop out when the right front wheel had to work. after replacing the transfer case shift motor i still had the problem so i put all 4 wheels on jack stands and put truck in gear in 4wd and finally figured out the right front wheel wasn't fully engaging. when i tore into it thinking it was the hub i found the actuator had broken apart and wouldn't slide evenly so i ended up replacing the hub and actuator. haven't had the issue since. so yes i recommend checking the wheel end actuators
Old Nov 26, 2012 | 05:50 AM
60DRB's Avatar
OP, Did you ever get your problem fixed?
