Info re: Moog Upper Ball Joints
As stated by me and others, Moog's upper control arms come with a serviceable ball joint which can be replaced when needed. Well, I just learned from Rockauto, who spoke with Moog directly, that they don't MAKE a BJ for this UCA nor do they make a replacement boot. WTH?!? This is the main reason I went with Moog in the first place. Their suggestion is obviously to buy a new UCA.
My issue is that my BJ boot is torn but the BJ itself is good so I am looking at the Energy Suspension polyurethane boots. I still need to take it all apart so I can measure the shaft for the correct boot. http://www.energysuspensionparts.com...Dust-Boots.asp It sucks but it looks like the boots are sturdier than the rubber Moog boots. So...if you are looking for a replacement UCA, make sure they make the BJ replacement and don't assume like I did... |
That's always been my assumption with the Moog UCA (that they were not replaceable). I don't think any one makes a UCA for these trucks that have replaceable joints, except for very high end, maybe. The advantage of MOOG is that they have zerk fittings and usually of better quality over oem.
Thanks for that. I've had my 4" Rancho Lift Kit with 35s on for a year now, replaced the the endlinks with Moog ones back then and I think they are already bad! I may just do the UCAs too then.
If you get the Moog UCAs, paint them before installation cause they'll rust and look shabby. As for the boots, I just ordered the Energy Suspension replacements and I'll post part# and feedback after I install them.
Thanks and let me know.
I assume this one is it: (I've already replaced the stocker one twice!) http://www.ebay.com/itm/Moog-K80306-...sories&vxp=mtr and bushing (doesn't look as strong as the ones you posted) whenever I need to replace it: http://www.ebay.com/itm/Moog-K80417-...sories&vxp=mtr Out of curiosity, what did you spray yours with? I was debating just doing herculiner if that would work there. |
Originally Posted by edgespeeder06
(Post 4895049)
I assume this one is it: (I've already replaced the stocker one twice!) http://www.ebay.com/itm/Moog-K80306-...sories&vxp=mtr and bushing (doesn't look as strong as the ones you posted) whenever I need to replace it: http://www.ebay.com/itm/Moog-K80417-...sories&vxp=mtr Out of curiosity, what did you spray yours with? I was debating just doing herculiner if that would work there. http://www.energysuspensionparts.com...p?prod=9.13136 As for painting, I didn't but I will once my bushings come in. I may just use plain old Rustoleum in matte black. |
Wow, that's a huge bummer about non-replaceable joints. Was literally just about to order Moogs since my Camburgs wont fit when I take the lift off. Now what to do...
Originally Posted by mSaLL150
(Post 4895121)
As far as painting them, I had an open can of POR-15 and used that, two years and it is still black and no rust....great paint (coating). |
Where did you guys get your Moogs?
Originally Posted by StoveTop
(Post 4895092)
So the K80306 is the correct part (left side) but they come with bushings so you wont need those. I replaced the ball joint boots and these are the closest to the meausrements of the Moog BJ:
http://www.energysuspensionparts.com...p?prod=9.13136 As for painting, I didn't but I will once my bushings come in. I may just use plain old Rustoleum in matte black. For Moog parts, I've bought them on Jegs in the past but I plan on looking around for the best prices. |
(Post 4895189)
I was just at some online site looking at Moog parts and it looks Expensive to buy all the parts I think I need. I may have to just buy all my parts in pairs, as needed, as opposed to just buying everything and doing it all at once. I hate that. Here is the site.
http://www.moog-suspension-parts.com...s.asp?cat=3701 |
Originally Posted by randude1999
(Post 4895314)
Sounds like 2004 is a year to avoid with f150. I have been reading about the breaking spark plugs too.
I have a squeak in something down there and need to replace something pretty quick. I hate noises in my truck |
Originally Posted by sam1947
(Post 4895265)
RockAuto or O'Rileys will have probably the best pricing.
