how to clean COPs (coils)
Old Sep 3, 2012 | 07:12 PM
BLACKOUT/TX's Avatar
I have a 2005 F150 5.4 3v supercrew, have noticed some hesitation when going uphill or when in low rpms, have heard these trucks have some problems with coils, i replaced #8 coil by firewall and cleaned throttle body and truck was fine for bout a week then noticed same hesitation, what can I use to clean then with before I decide to waste $275 on some accel coils, any suggestions????
Old Sep 3, 2012 | 08:08 PM
Ray21's Avatar
Not sure if you can really clean them or not effectively. You can replace the boots and connecting springs if they're torn or corroded though. If its a problem with the coil itself then you'll need to replace it.
I've used coils off amazon and eBay with success, they've much cheaper than others I've seen.
Old Sep 3, 2012 | 10:24 PM
sam1947's Avatar
Do some searching on the site, The Accel Cop's are not a favorite at all. How many miles ?? Have the plugs been changed ??
Old Sep 4, 2012 | 05:42 AM
The 05's also have the fuel injector issues.
https://www.f150online.com/forums/v8...ram-07m08.html
Old Sep 7, 2012 | 02:42 PM
Im at 100k but havent changed plugs yet about to change them when i decide on which coils to purchase, i plan on putting in some e3 plugs i heard they perform great, i hope its not a fuel injector issue i know that can be expensive to get repaired/replaced thanks guys!
Old Sep 7, 2012 | 02:58 PM
When you change your plugs.....you can just get the boot for the cop....also its a good time to upgrade to granetelli direct connectors($100/set) rather then rely on the stainless spring for spark...
http://www.ebay.com/itm/Granatelli-H...sories&vxp=mtr
Old Sep 7, 2012 | 05:57 PM
SoonerTruck's Avatar
Use motorcraft plugs.don't replace the cops unless you have problems after the plug replacement.
Old Sep 7, 2012 | 06:11 PM
DespicableMe's Avatar
Do we have a written procedure on applying dielectric grease to the boots/springs?
Also, 88racing, are you aware if these Granatelli's work on the new style head using the 8L3E COP? My first thought is no.
Old Sep 7, 2012 | 06:52 PM
sam1947's Avatar
Do your research, the E3's haven't had a very good track record in these engines (me included). Go with what is supposed to be in that engine: Motorcraft.
