Need help please!!!!
I need some help guys! My window regulator went out in my 05 FX4 SCREW, front passenger window. I bought a Dorman replacement from AutoZone for $139. Brought it home, took the door apart and took the old one out. After putting the new one in I quickly realized the new one had a pigtail wired into the motor with a square plug. The old one had a hole in the motor that the stock door wiring plugs into with a round plug!! Called AutoZone back and looked at Dormans website, both saying it is the correct regulator! Has anyone had this damn problem?? I need to get this figured out soon. Thanks for the help.
It's been a few years since I did mine, but I seem to remember a short cable that went from the motor to the square plug. Check the cable in the door and see if there is a square connector further up the wires.
Finally fixed the window..you were right JR, there was a square plug that had a pigtail attached to it that had a round plug on the end. It was completely taped up, didn't even see that it could be removed. Thanks for the help. Feels good to have a working window again!
