Brake Controller for my 07 and a Weight Distribuition Hitch?
Old Aug 26, 2012 | 04:23 PM
Hi guys, im looking at getting a travel trailer soon and starting to get the truck ready to pull it.. Im looking at this brake controller http://www.etrailer.com/Brake-Contro...eid=2007104500.
Is it a pretty good one, or anyone have this one?
Also my truck came from ford with the towing package, it has the 7 way plug, 4 way plug, trans cooler etc. Ive read that this controller should be just plug and play since the truck already has the towing package, any idea where the connector would be to plug into the controller?
Im going to get a WD hitch, which one is a good one to go with?
Old Aug 26, 2012 | 10:35 PM
avfrog's Avatar
That is a great controller. I have a p3 and it does an excellent job. It should be just plug and play for you once you get the harness for your truck.
Old Aug 27, 2012 | 03:32 PM
It plugs in behind the dash near the OBD2 socket. The one in your link does come with the adapter cable for plug and play.
The guys in the towing forum could probably steer you right for a WD setup.
Old Aug 28, 2012 | 12:28 AM
HotBlue05SCREW's Avatar
There should also be a relay that plugs into the fuse box. At least I had to plug it into the fuse box
