New to forum and i need help
Old Aug 1, 2012 | 08:26 PM
Take it to a muffler shop, they can check for clogged cats.
Old Aug 1, 2012 | 09:40 PM
f0rd1926's Avatar
Is there 4 cats on the truck or just two
Old Aug 1, 2012 | 10:15 PM
just 2.....one for each side
Old Aug 1, 2012 | 11:18 PM
f0rd1926's Avatar
Ill have to have the cats checked. I am pretty sure its the manifold now i will check that tomorrow not to sound like a noob how would i check it just visually or is there a trick
Old Aug 2, 2012 | 10:54 AM
f0rd1926's Avatar
I tried to get the cel to come on while comming on the freeway. I gunned it and it started shaking violently and back firing bad.
Old Aug 2, 2012 | 12:23 PM
Old Aug 2, 2012 | 12:50 PM
Spark plugs and possibly coils. You do need to check the FPDM for corrosion.
Old Aug 2, 2012 | 04:34 PM
f0rd1926's Avatar
Im going to buy a coil tomorrow morning and change it one by one to see if there is a bad one im doing everything i can to not change the plugs.
Old Aug 2, 2012 | 04:36 PM
f0rd1926's Avatar
The fpdm is above the spare. Im going to check that but if it is bad wouldnt it not run at all?
Old Aug 2, 2012 | 04:46 PM
4v4eye's Avatar
What would the readings be if it was plugged? Higher I assuming?
Old Aug 2, 2012 | 08:29 PM
Change them. They should be done every 60k.
Old Aug 4, 2012 | 12:26 PM
f0rd1926's Avatar
I took the truck to an exhaust shop they said bad manifold is the culprit thanks everyone
