Control issue
Old Jul 10, 2012 | 03:02 PM
kingfish51's Avatar
Originally Posted by RUSTY06CREWFX4
http://www.falkentire.com/template.php?page=technical
From this chart, the loading looks progressive. Scroll down to the Light Truck Tire Load and Inflation Chart.
If you mean the lower the tire pressure used, the lower the load carrying ability, then yes it is progressive.
Old Jul 10, 2012 | 03:21 PM
RUSTY06CREWFX4's Avatar
For example:
Look at LT265/70/16 single Load range E.
80/70= 1.143*(2765) =3160lbs /=/ 3415lbs shown
80/75= 1.067*(2900) = 3093 lbs /=/ 3260 lbs shown
One can not just half the pressure (80psi/40psi) and assume the capacity is halved as well. I would expect that load range e tire to have a capacity of at least 1910 lb at 35 psi with no harm done.
Old Jul 10, 2012 | 03:31 PM
kingfish51's Avatar
For example:
And you would be wrong.
Old Jul 10, 2012 | 03:42 PM
So according to your opinion and that chart, I can not run a LT265/70/16 single Load range E at anything less than 70 psf or it is unsafe?
Old Jul 10, 2012 | 03:54 PM
http://www.tirerack.com/tires/tirete...jsp?techid=194
Additionally, while a tire's maximum load is the most weight the tire is designed to carry, its load carrying capacity at lower inflation pressures is proportional to how much inflation pressure is used. For example, P235/75R15 P-metric sized, standard load (SL) and extra load (XL) tires used on cars would be rated to carry the following loads at the inflation pressures indicated:
Air Pressure (psi) 20 23 26 29 32 35 38 41
P235/75R15 SL 1543 1635 1753 1852 1940 2028
P235/75R15 XL 1543 1635 1753 1852 1940 2028 2105 2183
Note: 35 psi is the assigned 'maximum load' pressure for standard load tires and 41 psi is the assigned 'maximum load' pressure for extra load tires.
The above chart correctly shows that an extra load tire is not rated to carry any more load than a standard load tire when both are inflated to the same pressure (up to the standard load tire's 'maximum load' pressure of 35 psi). This is because a tire's load capacity is a function of its size (which determines the size of the 'air chamber'), its construction (which determines how much pressure can be held) and the actual air pressure used (which determines how many air molecules are forced inside the chamber). All tires with equivalent physical dimensions carry equivalent loads (until they reach their maximum load pressure).
The tire's maximum load is indicated in relatively small sized print branded near the tire's bead (adjacent to the wheel) indicating the appropriate value. Because tires are global products, their maximum load capacity is branded on the tire in kilograms (kg) and pounds (lb.). These values can also be found in the industry's tire load & inflation charts.
Obviously I wouldn't drop below what the door jamb says but why is the capacity at 20psf not 2183/2 or appox. 1091lbs?
Old Jul 10, 2012 | 05:32 PM
kingfish51's Avatar
Not at all. At 70 psi the LT265/75R16 is good to3105lbs. 2 tires = 6210lbs, far over your GAWR. 50 would be about the right pressure for that tire. Not that a 16" will fit on your truck.
Why are you talking about extra load, and the extra load comes in due to the higher pressures available.
As my last words, Ford would not recommend 50 psi for a LR E tire if it did not need it. All it would do is wear the tire quicker if 35 was good enough. And with a recommended of 50, the TPMS would set a fault long before it hit 35, for good reason.
Old Jul 11, 2012 | 03:01 AM
ryanamy's Avatar
On my last truck I'd run around 65psi when unloaded, and 80-90psi when loaded. Took a little of the rough ride out of the 3/4 ton dodge. Over 60k on one set of tires and they weren't wore out when I sold it and never had any tire problems doing that either.
Old Jul 16, 2012 | 07:32 AM
knighthaq's Avatar
Thanks for all talks help
knighthaq's Avatar
Thanks for all yalls help
