Sluggish Performance after plug change
I changed all 8 plugs on Friday morning. I eased each one quarter of a turn and sprayed PB Blaster to allow them to soak. After 20-30 minutes, I started the plug change, all eight came out without much problems. Replace all with SP 515 from Motorcraft. I am sure that some PB got down to the cylinders. I started the truck and lite smoke from exhaust. I know that this is just the PB burning off. Friday afternoon, I go for a ride and it is running horribly. Constant misfires, hesitation, and shaking so bad that my windshield wipers are jumping. I pulled each plug when I get home to check the over. All looked good but truck still is running like crap. Today, I pulled them and put the original plugs back in, to see if there was a difference. Truck still runs like crap. I have checked all wires, connections, and vacuum lines and everything looks good. Earlier, I went out and put truck in reverse and slowly revved up engine. It would not go above 1100 RPMs. I have checked everything I know to check.
Please offer some help.
did you use dielectric correctly?
Didn't use any = misfires
here's how to use it: https://www.f150online.com/forums/4829957-post17.html
did you change the boots?
No boots changed = potential for misfires depending upon their condition
did you use new boot-plug connectors?
No connectors changed = potential for misfires depending upon their condition
Thanks for the feedback.
That's interesting - these are typically not prone to OOTB failures.
Any pics or what specifically is wrong with it?
Just curious.
Just curious.
