2 piece hub question
Hey, I know there's tons on this site about all the brake stuff and hubs but just need a definite answer before ordering stuff online..
is this all the correct stuff to convert to a 2 piece hub up front
powerstop k1943 aswell as new spindle nuts centric part number 12465901 (X2) and centric hub part number 12465902 (X2)
thanks for the help!
http://www.centricparts.com/files/F1...20Retrofit.pdf
i ordered part # 120.65128 x 2 from partsgeek. came with new spindle nuts, and rotor, hub, bearing assembly.
only thing is i need cross drilled and slotted rotors so its a different part number..
just needed to know if im ordering the right hub.. wanted to order from rock auto for the hub and a different site for the rotor and pads.. trying to get the best deal
that part number you gave me says 04-07 i have a 2008.. i know its the same truck just the site says its not the same kit.. did that one convert it to a 2 piece or just keep it stock?
