Noise in front end, only in 2wd not 4x4 HELP...
2004 F-150 Noise in front end, only in 2wd not 4x4 HELP...
Well i have a 2004 Ford F-150 xlt 5.4L .1st i thought it was maby a vacuum leak. but then the noise got worse. so yesterday i took off the wheel, caliper, and rotor. i spun the hub while truck was running and cv did not move, like it suppose to. But only when i drive in 2wd the noise is there as soon as i hit the gas or even when im coasting. ANY ideas i will take. iv tried everything i know about it and still makes the noise. my guess the 4x4 is not fully disengaging in the front driver side tire. but I'm an HVAC/plumbing mechanic. not auto.
Last edited by Chris D'Angelo; Apr 9, 2012 at 04:59 PM. Reason: forgot to add a someore things
